View Single Post
Old 08-05-2008, 08:58 PM   #160 (permalink)
TalonESIT
Proven Member
Region: SoCal
Classifieds Rating: (0)
Reputation: TalonESIT is pretty helpful and trustworthy
Quote:
Originally Posted by Shadow98 View Post
It makes more sense to mount it that way, because you have the WG on that side as well. The only other car I've seen with that manifold, had the turbo mounted the other way and the WG was pretty much right on top of the compressor. Now, I know that if you have a FMIC, the air will cools off some, but you starting with hotter air making the IC work harder...
Nice job Slippi
I can see one fabricating a downpipe for this setup, but I doubt there will be a lot more of these right away unless everyone removes their AC systems. Slippi won't need AC so he is in the clear... I've been studying the pictures pretty close and (although I know you will fix the issue) there is no clearance for your intake unless you run an open turbo or custom intake of course. There seems to be no chance if you're running AC though.
Offline
[posts] Reply With Quote
Sponsored Links
