Pics of my crank!
_95GST_
117
Feb 1, 2006
Apple Valley, California
Here are some pictures of my crank! Does anyone know how this happened? I thought it was just crankwalk at first but when I pulled off my bearing and saw that LOL imagine my surprise!
Thanks!
No but seriously does anyone know how this happened?
I really need some help with this guys! Do anyone of you have any Ideas why this happened? I don't mean to keep posting, I just can figure it out and I want to order the new parts for it ASAP!
Thanks
Honestly I'm not sure you did anything wrong. There are several things that come to mind, first one is over rev, next would be weak crank, third would be an underground crank that the oil holes weren't de-burred properly. I'd say get another crank in there and get back to breaking parts :D.
Good Luck!
Ray
Judging by the hardware, that's a stock shortblock. How old is it and how long have you been beating up on it? Either way, the engine's gonna have to come out. I would DEFINITELY keep that bad boy as a memorabilia, that's what I do with all of my broken shit (up to a crank and a bent rod now).
I have similiar pictures. I cracked one very close to that spot. Had a Material Engineer look at mine at work. He thought there was a small flaw when cast and it eventually failed. Mine went on the way to get coffee before work. Drove it 5 miles like that.
Good Luck!
Ray[/QUOTE]
Thanks for the info! I was always really good on not over revving it.
Judging by the hardware, that's a stock shortblock. How old is it and how long have you been beating up on it? Either way, the engine's gonna have to come out. I would DEFINITELY keep that bad boy as a memorabilia, that's what I do with all of my broken shit (up to a crank and a bent rod now).''
I blew my motor once so I did a rebuild and have been running it for about 30,700 miles. I do have the engine out right now. O yeah for sure im going to keep it, I never seen that before LOL. yeah I was running it with a harmonic balancer.
My thoughts are that your harmonic damper crapped out or maybe that particular cylinder experienced a lot of knock. Got a pic of the damper, or maybe a better one of the bearing near where your middle finger is in the pic above? I'd really like to see the rest of that rod and your oil pan contents as well.
Good Luck!
Ray
Ray, I'm assuming you mean that it cracked due to a stress riser from a sharp edge left after it being ground and not deburred?, and not that the actual grinding caused it to be weaker....
I saw that last night. OMG I assumed it was just a flaw in the casting. It happens, you replace and go on.
d
thats just sick nuts, tear down, rebuild, race, and when it breaks repeat :thumb:
I will get the crank out tonight and ill post some more pics, and some of the contents of the oil pan! If there is any pics you guys want me to take just let me know!
thanks!
  • For sale 1g 90 Oil Cooler
    • kyler021
