I photoshopped it for you (see the link you posted). I think it'd look really good!
If you drag race most (which I'm assuming you do - versus autox and road racing), I would go with the lighter wheels. If you also do a good bit of autox and road racing, then I would really consider looking into different rims that would be wider with less weight than the Slipstream's. Unless you really need/want the wider tires, I would think the lighter ones would be better. You'd be saving a little over 20lbs. And as you can see, Tim runs them (the 16x7) and has good success with them.
____________________________
Brian
