ok when i say the car acts like the clutch is not engaged i mean it doesnt turn over at all it doesnt even try to turn over. If you go out to your car and try to start it with out the clutch pressed in. Thats exactly what mine does. I tried it earlier this morning to make sure that i got the same result when it was pressed in as i did when it wasnt. My radio clicks off like the car is trying to start and but not a movement from the engine. I guess it could be something to do with the ignitions cylinder but i dont understand why releasing the clutch and then depressing it again would work every time so far. to my knowledge changing the ignition cylinder will not really be a boat load of fun compared to just unplugging the safety switch. I will try and get a video in alil bit. Maybe that will help. Until then like i said go try to start your car with out the clutch engaged and thats exactly what i got going on
