Small 16g limits
DeadlyEclipse95
74
2
Jul 30, 2004
Huron, Ohio
I recently picked up a 90 GS-T with a small 16g, 2g manifold and a buschur racing 2.5 inch 02 housing for $400... I want some setup ideas to push this little turbo as fast as it will go...all help would be appreciated as I have a $150 bet with a kid with a turbo escort who thinks that dsm's are junk and that he'll beat mine...help me put this kid in his place
190 fuel pump, set of evo 560 injectors, fmic with piping, manual boost controller, air intake, 3" exhaust, something to log with, and something to control the injectors. a wideband would be nice too. that should give you quite a bit of get up and go.
also dont forget to do the regular maintenance first.
I'd love to introduce him to my buddy's 2G TSi AWD. 136k on the STOCK 7-bolt motor (supposed to be junk) running 18-22psi; it's run consistent 12's for the past 4 years (ever since he bought it with 101k).
Let's see an Escort do that.
A good buddy of mine from Maryland owned a '97 GSX and sold it with a staggering 186k on the stock 7-bolt. No internal mods other than cams, and I think he was running a Bullseye V-Trim at 20-ish psi daily.
After the car sold he lost contact with the new owner, so we're unsure if the car's still on the road or still has the stock 7-bolt.
Yesterday i changed the water pump, timing belt, balance shaft belt, spark plugs and wires...I just want to see what kind of power i can get out of this small 16g and stock 6 bolt.....I also want to inform everyone that this escort is somewhat fast, its fastest time at the track was a 13.2, I know that this gs-t is more than capable enough but I want an extremely strong setup, I will be tuning it using a vpc that i got off of my buddies 1g all wheel, i also have a punishment racing aluminum radiator and prothane motor mounts, as the factory ones were completely toast, it also has a 3 inch exhaust and i have a set of MH Racemaster slicks
I pushed my small 16g to over 36 lbs/min. What can you do with that amount of airflow?
. . . You havn't stated the escorts dyno number, 1/4mile speed/time. This leads me to believe that he hasn't told you :) . Do you know? You are "deadly eclipse" if you don't take it to the track. He doesn't need to go. Just show him a timeslip and tell him any real competition isn't afraid nor incapable of putting his car on the strip and documenting his results.
yea but can the guy drive? anyone can have a fast car but do they know how to use it?
i saw a built 03 svt cobra which is s/c get destroyed by a basicaly stock srt-4 the guy in the svt couldnt drive, but you say 200 hp? a there are dsms with over 500whp on a stock 6bolts block :D
I put down 397whp on my stock 6 bolt on a dynojet, only made like 350ish on a dynapack, the tuner told me his dynapack was low reading.
This was on 22psi and 94 octane.
Hell i would run him right now as your car sits, just buy a Boost controller turn it up to 14psi and run him from a dig.
Hell i ran a friend of mines GTO from a dig and had him to the top of 3rd till he started to reel me in but in 1/8 he would have got me by maybe 1 car and that was when i had 187,000 miles on my original motor and bone stock car w/ boost controller set at 14psi.
Run him this weekend let us know how it went, but only run him from a DIG, wich he probly wont since it's FWD and nobody wants to run from a dig anymore...panzys.
im sure you can, but do you have the money to? i mean yea the turbo should be able to help your car into 12's but the turbo wont alone, you need all the mods to make your car be able to do it, cam, valves, valve springs, built the head it would help, a nice fmic, new turbo mani. exhaust i cant remember if you siad you had one or not. o2 housing, ecu. but yea its possible. dont wonder if it can find out if it can :D you got a dsm you can do anything you put your mind and money to
I'll keep you guys posted...this race will be happening in a couple weeks in Norwalk....I'm busting my ass to get this car together...my punishment racing radiator and fmic just showed up yesterday, i'm just waiting on a new clutch and flywheel and some time on Buschur's dyno
what clutch you get? and what fmic? get a short shifter too :D its worth the 50-60 bucks
  • For sale 1g 90 Oil Cooler
    • kyler021
