View Single Post
Old 06-27-2008, 11:37 AM   #17 (permalink)
Morphius
Proven Member
Morphius's Avatar
Region: Midwest
Classifieds Rating: (0)
Reputation: Morphius is extremely helpful and trustworthyMorphius is extremely helpful and trustworthyMorphius is extremely helpful and trustworthy
Quote:
Originally Posted by hopwoodp View Post
Has anyone found where to get a larger diameter master cylinder? I am guessing one that is 11/16" to 3/4". I would prefer to use the master cylinder for this than the slave cylinder, due to the overthrowing of the clutch for stuff. =)
My reason for this is because I have the ACT 2600 clutch and have some bad arthiritus in my knees. If I can find out where to get one, I will be doing this asap.
Although I haven't tried it myself, I know there are 2-3 people on here that have used the 3000gt VR4 slave with success, after I recommended it. At least with a ACT2600 clutch. Sorry, I don't recall who. If you're running a 2600 or clutch with similar pedal load, you shouldn't have any issues. The pedal crossshaft flexes enough as it is, I don't see anyone overstroking the clutch. Install it. Set the pedal up as it should, per the manual. Pay attention to where it releases/engages. Typically, in any vehicle, the clutch is designed to release 25-35mm off the floor.
Offline
[posts] Reply With Quote
Sponsored Links
