Thread: New log.
View Single Post
Old 06-23-2008, 11:39 PM   #2 (permalink)
blcknspo0ln
DSM Wiseman
blcknspo0ln's Avatar
Region: Tri State
Classifieds Rating: (4)
Street logs always have some crazy variation in hp/tq numbers. You can do back to back pulls on the same run and they'll show different numbers. It's best to regard them just as an estimate or baseline, if anything. What advice are you looking for concerning your logs? You're 70-90 is rather slow (close to 4 seconds) for 28 psi on a 16G. What boost are you really running?
If there are two things I'd recommend, it'd be first to fix your TPS (.63V at idle) and to correct/dial in your boostest/airflow. It looks like you are artificially inflating your airflow by tweaking the tables by that much. Any reason for it? MAF-T? Are you verifying that dsmlink is reporting the same AFR's as your UEGO gauge?
____________________________
~Tom
Offline
[posts] [gallery] [blogs] Reply With Quote
Sponsored Links
