2.5" ID coilover springs compatible with stock rear upper spring perch?
hsk8te2006
182
Jun 9, 2007
Ann Arbor, Michigan
Background: I drive a '96 spyder turbo. The car is my daily driver, and I have no intention of racing it anytime in the near future.
I'm planing on getting a set of 2.5"ID coilovers from Ground control, as well as Koni yellows and RRE's front upper plates. However, I was hoping to use the stock rear mounts 1) to keep the rubber shock mount so the ride is a little less harsh, and 2) to save the extra $200.
I jacked my car up, and it looks like a 2.5" ID spring wouldn't work with the stock rear upper spring perch though... I looks like the perch is designed for roughly a 3 or 3.5" ID spring. Am I right in saying that I can't use the stock rear upper spring perch with a 2.5" ID coilover spring?
Does anyone know what I could use to set the spring under that would work with a 2.5" ID spring, and NOT send the weight of the car into the shock rod (as a coaxial hat does)?
Thanks in advance!
The Ground Controls were designed so that you still use the stock mounts front and rear.
what is the black hat that the spring is in made of? i got a set of ground controls but they dont have the top hats so i need to make some but i dont know what to make them out of.
