2G 2g DSM Engine Bay Electrical Connections
This article is designed to help 2g owners identify all the plugs in the engine bay.
The photos and wire colors were based off of a 1999 Eclipse GSX, so other years and models may vary in location and wire color.
I would like to give a HUGE thanks to turbosax2 for helping with the photography and the documentation for the article!!
The way the tech article will be set up will be as follows:
This post will have the master list of all the connectors. Each connector will then have it's own separate post below which will contain a little description and a few pictures and diagrams. The first picture will be an overview shot to show the general location of the plug. The plug will be circled in green. The next picture will show the plug itself. Following that will be a picture of the back of the plug to show how the wires are inserted into the plug as well as wire color. And lastly will be a diagram showing the arrangement/layout of the wires as well as the wire colors. These diagrams will always be viewed when looking at the back of the plug with the clip (the part that holds the plug in) on the top.
Some descriptions will come from the service manual and others from Virtual Tour of the DSM Engine Bay - Quadrant map.
Master List
1. Manifold Differential Pressure (MDP) Sensor
2. Fuel Injector 1
3. Fuel Injector 2
4. Fuel Injector 3
5. Fuel Injector 4
6. Ignition Coil (Coil Pack)
7. Ignition Power Transistor
8. Throttle Position Sensor (TPS)
9. Knock Sensor
10. Camshaft Position Sensor
11. Auto-Cruise Control Vacuum Pump (Cruise Control Actuator)
12. Volume Airflow Sensor [Mass Airflow Sensor (MAS)]
13. Fuel Pressure Solenoid (FPS) Valve
14. Exhaust Gas Recirculation (EGR) Control Solenoid
15. Condenser Fan Motor [Air Conditioning (A/C) Fan]
16. Brake Fluid Level Switch
17. Radiator Fan Motor [Main Fan]
18. Hood Switch
19. Dual Pressure Switch (AC)
20. Capacitor (Noise Condenser)
21. Left Headlight
22. Left Combination Light (Parking)
23. Left Side Marker
24. Right Headlight
25. Right Combination Light (Parking)
26. Right Side Marker
27. Evaporative Purge Solenoid
28. Theft Alarm Horn
29. Idle Air Control Motor (ISC, IAC)
30. Turbocharger Waste Gate Solenoid Valve [Boost Control Solenoid (BCS)]
31. Back-up Light Switch
32. Front Wiring Harness and Control Wiring Harness Combination
33. Evaporative Purge Solenoid to ECU Harness Connector
34. Crankshaft Position Sensor (CPS)
35. EVAP Emission Purge Control Solenoid Valve
36. Air Conditioning (A/C) Compressor
37. Engine Coolant Temperature Gauge Unit
38. Engine Coolant Temperature Sensor
39. Heated Oxygen Sensor (Front O2 Sensor)
40. Starter Solenoid
41. Vehicle Speed Sensor (VSS)
42. Positive Battery Cable/Starter Motor
43. Left Fog Light
44. Right Fog Light
45. Generator (Alternator Power)
46. Generator (Alternator)
47. Power Steering Pressure Switch
48. Horn
49. Oil Pressure Switch (Dummy Light)
50. Oil Pressure Gauge Unit
51. Ignition Suppression Resistor (Fuel Injector Resistor Box)
52. Engine Speed Detection Connector
53. Windshield Wiper Motor
54. ABS Hydraulic Brake Unit
55. Left ABS Sensor
56. Right ABS Sensor
Wire Color Key
B = Black
Lg = Light green
Sb = Sky blue
V = Violet
O = Orange
Y = Yellow
Br = Brown
G = Green
Gr = Gray
L = Blue
P = Pink
R = Red
W = White
Here's an example on how to read the diagrams.
If you look at the picture, you'll notice there is 2 wires coming out the back of the connector. The diagram has 2 boxes that contain letters from the color code list above. The first box contains RSb. The first letter is the main wire color - red. The second letter (if applicable) deals with the stripe color, which in this case is sky blue as you can see in the picture. The second box contains a G for green. There is no stripe on this wire. These diagrams only deal with main wire color and stripe color. Some of the diagrams contain blank boxes which just means there is no wire there.
The MDP sensor measures the amount of vacuum in the intake manifold. It does not do this to measure the amount of air entering the engine. The MDP sensor measurement is instead used to monitor that the exhaust gas recirculation (EGR) emissions control system is working correctly. 1G cars used a temperature probe for this, while 2G cars use the MDP sensor. (from Virtual Tour website)
This plug is held on by this little wire clip. Use a small pick or screw driver to pry the clip up. Once this is removed, then you can remove the plug.
http://www.newunitedracetech.com/sh...or-p-1381.html?cPath=1114_1145_1146_1147_1148
7. Ignition Power Transistor (Power Transistor Unit [PTU])
The engine control module controls the two ignition power transistors to turn them alternately ON and OFF. This causes the primary currents in the ignition coils to be alternately interrupted and allowed to flow to fire the cylinders in the order 1-3-4-2.(from service manual)
The TPS is connected to the throttle plate inside the throttle body. It provides an electrical signal that "tells" the engine control computer the throttle position. The ECU uses this information to help "decide" how much fuel to inject in to the engine. (from Virtual Tour website)
*This plug also has the wire clip that holds it on (the same as the MDP sensor).*
http://www.newunitedracetech.com/sh...tle-Position-Sensor-TPS-Connector-p-1388.html
10. Camshaft Position Sensor (2Gb location)
Yazaki SSD Sealed Connector Series 3 Female Housing [Black]
KUM 090(NMWP) Sealed Series 4 Position Female Housing [Black] {P.B.T} [PB625-04027] : New United Race Tech, New United Race Tech
KUM 090(NMWP) Sealed Series 4 Position Female Holder [Orange] {P.B.T} [PB875-04900] : New United Race Tech, New United Race Tech
This is a very important component of the engine, since it "tells" the engine computer how much air is entering the cylinders. The MAS actually consists of three different sensors: air flow, air temperature, and barometric (atmospheric) pressure. (from Virtual Tour website)
This solenoid allows the engine control computer to temporarily raise the fuel pressure for hot starting purposes. This is accomplished by cutting off the vacuum hose going to the fuel pressure regulator
It is not used for anything else, but it can provide a useful tap-in point for a boost gauge, since the regulator "sees" the intake manifold pressure. (from Virtual Tour website)
It controls the flow of exhaust gas through the exhaust gas recirculation valve - a valve that allows some exhaust gases to run back into the intake stream. This is purely for emissions purposes, as "reburning" some of the exhaust gas helps reduce emissions. (from Virtual Tour website)
KUM 090(NMWP) Sealed Series 4 Position Female Housing [Gray] {P.B.T} [HN025-04127] : New United Race Tech, New United Race Tech
  • For sale 2g 2GA Turbo/Automatic Engine Harness
    2GA Turbo/Automatic Engine Harness $225 + shipping & paypal fees* all plugs are complete and...
  • For sale 4G63 6 Bolt Oil Pump Pickup ( great condition )
    6 Bolt Oil Pump Pickup $65 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G OEM BOV Hose ( great condition )
    2G OEM BOV Hose $25 + shipping & paypal fees* great conditionYou must be registered to see...
  • For sale 1g 1G OEM BOV & Vader Cap
    OEM 1G BOV & Vader Cap $45 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 1g LSD 4 Bolt Rear Differential
    1G LSD 4 Bolt Rear Differential $250 + shipping & paypal feesYou must be registered to see...
