New best for the Mirage - 8.47@169MPH
Nice numbers! What did you end up doing for a tranny after it blew at the SO?
Well, it didn't exactly "blew up". The crank bolts snapped. We made some changes on the converter so the crank bolts can sit deeper in the crank. It's the same trans since the beginning of 06. It probably made around 100 passes since.
Thanks for the good comments guys!
Nice job!! Also nice to see someone else on here from Montreal!
Are you running stock bolts? We drill out the tabs on the converters and tap them to take a 7/16 bolts.
We broke the bolts that hold the flexplates to the crank, not the converter bolts. Converter bolts are not stock, but crank bolts are.
