View Single Post
Old 05-28-2008, 09:54 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
blcknspo0ln Offline
DSM Wiseman
blcknspo0ln's Avatar
Tech Posts: 5,312
Classifieds Rating: 4
Screw on the male fittings that are supplied in the kit. You can choose whatever fittings you like, depending on how you mount things. BE CAREFUL to not overtighten the fittings. These are not to be gorilla-handled and they are very easy to overtorque and crack the housing. You can tell how I found that out :( Also make sure to use the small bottle of GOOP tht is supplied. It is a liquid sealant that is resistant to methanol and is highly recommended to be used on the fittings before installing. Make sure you HAND tighten the fitting and then take a wrench to turn it another 1/2 turn. that's it.
Next, observe the cap on the pump. There are directional arrows in which the pump flows fluid. Hook the lines up as follows:
tank > pump > nozzle (on TB)
Feed the nylon line from the pump to the fitting on the throttle body by any means you feel necessary. Some route the line under the car, some route it through the cabin. I chose to run mine under the passenger carpet side and through the firewall to reach up into the throttle body.
Now for the wiring:
*precaution* DO NOT use too much force when pushing in the knobs for the START PSI and FULL PSI on the 2D controller. I made a $125 mistake when I broke the thing clean off while trying to adjust START PSI.
here are both of my broken units during my install:
If you should happen to break the controller during install, you can contact Snow Performance directly and buy a new unit. If you break any part of the pump, reference here for part numbers and reference here for the list of dealers in your area to buy from.
____________________________
~Tom
View this member's Blog
