5 speed t-case on an Auto
20psimitsu
131
Aug 22, 2002
San Antonio, Texas
Installed a standard transfer case on a 90 GSX auto and wanted to know if anyone has had any problems doing this. Also wanted to see if there were any downsides to doing this.
if i remember the bolting pattern is diffrent and the gear ratio is also diffrent. I'll have to find my book to see for sure..
The A/T and M/T transfer cases show the same 24/22 ratio on VFAQ:
http://www.vfaq.com/mods/Trannies.html
I would say the only problem would be in 2g's, and mixing late model T-case(2gb) with an early model transmission(2ga) or vice-versa:
Transmission Videos (2g gear set identification)
VFAQ states nothing about this in the chart which concerns me a little.
I thought it should be brought up; although I don't have enough experience to say definitively one way or the other.
My bad, i was told what ever the trans, make sure to have the matching Tcase. but yeah the splines would be diff.. my bad..
Didn't know if there was a difference between the two so, I figured that I'd ask. Thanks to all of ya'll for the info.:thumb:
The transfer case is in three parts; front, middle, rear...The middle section can be switched out and is the only VISUAL mounting difference between the auto and manual cases..The internals I know nothing for sure.....
