View Single Post
Old 05-14-2008, 03:13 PM   #7 (permalink)
50trimmed1g
Proven Member
50trimmed1g's Avatar
Region: SoCal
Classifieds Rating: (0)
Reputation: 50trimmed1g is an unknown
Thanks to you all. I am going to try to isolate the problem. I forgot to mention that the car will make the same noise even if I wiggle the curved arm that goes verticle to the hub area. But only if I wiggle it left and right. Does this also indicate outer tre. Should I just take off the outer tie rod end and wiggle the shaft again and see if there is still play in the inner tie rod.
Offline
[posts] Reply With Quote
