ECU+ is reading normally, havent messed with those wires. Im going to check a certain loom of wires in the engine bay and maybe even try new plugs and wires. I will post back later tonight. I did some searching and found some others with the same problem, the car sounds like a machine gun when boost comes on and at higher rpms and plug wires were the culprit in their case, because I did clean them during the wire tuck and maybe I pulled on them too hard when I was wiping them with a towel... wish me luck.
____________________________
97 awd DD
s16g w/supporting mods
