View Single Post
Old 05-12-2008, 11:28 PM   #2 (permalink)
snowborder714
DSM Wiseman
snowborder714's Avatar
Region: Tri State
Classifieds Rating: (14)
It would be much easier to read if you had only the 3rd gear pull (WOT from 2k RPM's to redline).
A few things I noticed:
-your coolant temps are very high
-it doesn't seem like you went WOT at all (based on your front o2 readings)
-you saw 15 counts of knock at one point
-you should log TPS volts
-you don't need to log some of those items (like mileage, torque, horsepower, and injon)
Why is your deadtime set to 315? According to this it should be around 210.
Do another pull with those changes and post it back (or in the link forums). You can also read through the links in the "getting started" thread on the link forums for more help.
____________________________
Brian
Offline
[posts] [gallery] [blogs] Reply With Quote
Sponsored Links
