View Single Post
Old 05-11-2008, 02:33 PM   #13 (permalink)
hdoerr
Proven Member
hdoerr's Avatar
Timeslip: 15.158 @ 92.190
Region: Gulf Coast
Classifieds Rating: (0)
Reputation: hdoerr is an unknown
If you are not running a thermostat then you should begin to use one. When I was into domestics the same thing would happen. I believe you can go as low as 160 temp. The problem occurs when the water never stops moving and therefore does not get a chance to cool in the rad. Hope this helps.
Offline
