Hey guys, sorry I haven't posted in a while. I've been really busy preparing for my new job in a couple weeks. Anyways, I have an update, but it definitely isn't a good one. I got my ECU, MAS and BCS in a couple days ago. I swapped it all out today. I did the MAS first and cranked the car, nothing. Then I swapped the ECU, again nothing. Finally I installed the BCS where mine was gone and bypassed my Greddy boost controller. That did nothing different as well. I'm really about ready to roll this damn car off a cliff. The only thing ignition wise I haven't checked is the transistor. I'm gonna check it tomorrow afternoon, but I'm not really getting my hopes up for it being bad. I guess I need to pull the EGR valve out and check it and start combing for vac leaks and broken wires.
Alan, I'm glad your luck is holding. I guess our problems in the end were caused by a different source, just causing the same symptoms. I'll post back tomorrow after I test the PT. If you or Tom has any more ideas I'm definitely listening.
