A logger.
Why do you want to run mid 20s psi? Why not later 20? or 21.324567432536324562psi? My H1c flows 4 lbs/min more at the same boost than my small 16g. You need to use a lb/min and/or hp goal to determine what your setup needs. Then log running up the boost and see what you can get. . .
. . . Truely, boost is just a sideeffect of any horsepower goal.
____________________________
Matt
dd '90 GST, Holset H1C
