Quote:
Originally Posted by Empir3 X
No. without touching the flapper at all when it is closed there is a gap where you can see through to the other side. It cant be moved in any way to cover the entire hole as is, but if it could be moved back a bit it would work. I guess i did not clarify enough in the description.......Thanks though
I won't be a huge help here, but I've read threads with the opposite situation; the flapper shaft walked out of the housing (yours went in) leaving a gap when the flapper is closed. I forget the complete solution, but you might try searching around for similar threads. You might also try PM-ing Mr Peepers. He's been tinkering with WGs quite a bit lately and, unlike me, might remember the details.
