Quote:
Originally Posted by JayRolla
So if you move the flapper with your hand it will cover the hole completely? If thats what is happening you can just weld the flapper to the arm so it will open and close fully if its doing what I think it is. My buddy also over ported his turbo and the flapper would catch in the hole and not cover it, he just did a little welding and it works fine, good luck!
No. without touching the flapper at all when it is closed there is a gap where you can see through to the other side. It cant be moved in any way to cover the entire hole as is, but if it could be moved back a bit it would work. I guess i did not clarify enough in the description.......Thanks though
