hellarough
- Apr 10, 2008
San Jose,
California
Ok so just last week I bought up a 99 eclipse gs. I had driven it like 100miles before it started to give me problems.
The first incident I had just turned the car off and ran inside to grab something.I came back outside and I tried starting my car and it cranked then turned over but died immediately. So, I tried it again but the second it turned over I hit the gas pedal to rev the engine which didn't work at all...it died again. On the third try it finally started and had no problems. In the next two days the same thing would happen; my car would die right after starting or have trouble starting then after about two tries or sitting for 2 minutes it would start and run fine like nothing had ever been wrong.
Now, a week later, my car will not start at all but it will crank without giving a single fire. I did open up the intake and clean the throttle body with a cleaner. After I did that, I tried again and one cylinder fired like the car wanted to start (this makes me think that my car is not getting fuel)
Here is the list of things I have yet to check for lack time or knowledge about how to test:
fuel pump
fuel relay
Camshaft Position Sensor
Injectors
Coil
sparks
If anyone could explain how to test these components, tell me other things that I need to test, or pass along a shop manual in any format I would greatly appreciate it. I just want to get back on the road asap and I am damn near broke.
fuel pump
fuel relay
Injectors
Coil
sparks
. Start by replacing your fuel filter first and foremost!!. Its maintenence that needs to be done anyway. Secondly, remove your back seat and turn the ignition to the on position and make sure your fuel pump is priming. Start the car and make sure the fuel pump is continuing to run. If spraying carb cleaner in your intake makes the car start when it wasn't prior, then theres a fuel issue presumably. Cam and crank sensors can be extremly tricky and in my case difficult to test properly. You can get used ones dirt cheap and replace them. get them off a previously running part out car.
I guess I am a little excited...I just want my baby back. Thanks for the advice!
me
