Ravenous
- 414
- 2
- Sep 20, 2003
West Linn,
Oregon
Oh, my bad. I'm viewing on my iPhone and the nut/pin kind of resembled the mustang logo. Thanks for the response.
update on the damage from VIR
So a stroker will be the replacement huh???
Got my TCE brake kit installed, and they work very well! I'll have pics later.
^Where are those pics?
On Saturday I finally got my car inspected. Then I spent the afternoon putting my test pipe back on and screwed in the AEM wideband. I took it for a drive and tested it out some. It doesn't read on the gauge any richer than 10:1 and I was just barely hitting that sometimes on WOT. So It might be at 9.8 or so. But man does fly for being so rich, only running 12psi, and without touching the DSMLINK tune yet. Now it's time to get my feet wet with tuning.
Also, I only have about 30 miles on my new tires/wheels and I can already tell it's going to make a huge improvement over what I had.
Did you properly calibrate the sensor before installing it? That might explain why it's running so well but reading so rich.
Small 16g,2g manifold and O2 housing and hard uicp,and hopefully new rims and tires within the next few weeks.
Eddie, be careful cutting wires in there - the wiring setup on these cars is such that when you cut out a switch it screws up everything (as I learned the hard way).
talonTSIDriver - What does the "good book" say about climate control harnesses in there for a 2G ??? Am I safe in removing them or no? I would think so, its just the AC/Heater controls.
Some preliminary pictures. Still a good deal of aero work to be done. And I'm fighting witha TPS issue. But since Chris lives out in my neck of the woods I figured I'd post up. And yes I know the hood looks funky, it's not bolted on in the pictures (made it easy to take engine bay shots).
BlackTopVR4/JakeDSM - Photobucket - Video and Image Hosting
They're 285/18's. And the widebody is better than fender flares. Most of my suspension is tubular. The front has some aero work we'll be doing this week then wind tunnel testing afterwards. The brakes just barely clear. They're Alcon XT6 calipers with a 1.375x12.9 rotor. Nothing is photoshopped other than Jess removing the PS cooler line that is hanging down in a few of the pictures. We were still trying to figure out how to do the PS cooling so when we wheeled it out for some early pictures it was still just hanging under the car. Original color was the 95 hunter green (dark green).
We were still trying to figure out how to do the PS cooling.
