Update was about to take my car to Top level Performance today but did more test. When I open the oil cap I can hear air coming from the crankcase when I take the hose off the pcv it stops. Im gettin 5psi instead of 3 psi with the hose off the pcv. I just changed the pcv valve could it still be bad? Also with the hose off the pcv I now hear a large leak on my lower intake manifold gasket on the coil pack side so im going to change the gasket now. I shouldnt be gettin air coming thru pcv valve correct? Im also gettin a fuel odor when I do the boost leak test.
