View Single Post
Old 03-01-2008, 08:14 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #24 (permalink)
Epic904 Offline
Proven Member
Tech Posts: 73
Classifieds Rating: 0
Reputation: Epic904 is more helpful than not
Quote:
Originally Posted by Streetsweeper21 View Post
Thanks for the respond. I changed the Pcv valve and I did a boost leak test with an air compressor and the boost gauge did nothin at all. At idle the gauge goes crazy at reads 0 and 1psi than when the car is warm it reads -10 vac. When I tried to make a pull it only would boost 5psi. This is really Pissing me off cause it feels like I jus spent a Thousand and some change for nothing. Next stop is the shop which I Hate wit a Passion. Ill take off the valve cover I guess next and see whats going on in there how could I tell if the valve is bent.
Your saying at idle it is going crazy and only has -10 in/hg? for vacuum. I would say that is a definate boost/ vacuum leak that you need to fix. The car should be at idle with 16-18 in/hg. Driving your car like that will cause you to break other things especially if your detonating the motor.
