OK I guess I need to be more specific. I'll put up a picture when the camera battery is recharged.
But it's a flanged fitting. The flange part has a hole in the middle, with two bolt holes on the sides. Kind of like a Stock DSM Oil Return flange. But it is threaded on the end for an oil feedline to screw into. If lucky, you might be able to fit a single grain of dry rice through it, if you're real lucky. The hole is TINY.
