My crank journals is bigger than whats in the bearing catalog
MidShipCivic
718
9
Apr 22, 2005
Orlando, Florida
I have on almost every journal .
Rod 1.796''
Main 2.269''
In the ACL catalog is says shaft for rod Min - 1.7713 / Max -1.7717
For main it says Min- 2.2433 / Max 2.2441
? I measured countless times to check if I was off this doesn't make sense.
Notice that you are consistently off by 2/100ths of an inch? I second trying another micrometer or checking the calibration on yours.
To measure a 2'' journal I can only use my new 2-3'' micrometer.
For the rod the 1-2'' is the only one I can use.
What brand of micrometer do you have?
Well I'm not sure but I have the same ones at school.
It's zeroed out on the 2'' bar. (blurry)
    • eclipsemf
