HELP any one in Tampa have a compressor for a Boost leak test?
808_SpyderGST
121
Jun 18, 2002
Miami, Florida
Hey I'm having some MAJOR CREEP issues does anyone in Tampa have a compressor I could use. I'm a hand tool guy so I'm SOL. I gotta get this creep issue under control. If you have tester that would be great if not I'll build one. I just want to use a compressor to check it so I dont have to do it at a gas station.
Creep has to do with your exhaust.If you mean LEAK issues visit the brothers.
brotherzracing.com.They are on lois ave off near dale mabry.
How would a boost leak help creep? Normaly people fix creep buy porting the flaper on the wastegate.
I have the turbo ported and the 02 housing ported, I'm just starting off with the basics and working my way up from there. Start with a boost leak test, if it helps great if not I'll move on to the next step.
Although I keep hearing that If I get the supporting mods (which I plan to do) and run 21 pounds It should eliminate all creep issues.
THANX, I will check out Brotherz Racing looks like a good shop. I never knew there was a DSM shop in Tampa.
    • eclipsemf
