Quote:
Originally Posted by kergilman
I had a similar issue w/ my 99GS. The speedo/odometer quit working. The sensor was still functioning but the pressed gear in the tranny was pushing back against the 90* speedo sensor gear and not engaging it. Also it was pushing the speedo sensor to the side causing a small gap around the sensor and a small tranmission leak... Luckily the gears were fine and I just had to get the tranny gear pressed back on...
When they come off, you are better off buying a new one. Most likely to fall off again.
