View Single Post
Old 12-22-2007, 01:15 PM   #11 (permalink)
bpestilence
Proven Member
bpestilence's Avatar
Region: Pacific Northwest
Classifieds Rating: (1)
Reputation: bpestilence is an unknown
Quote:
Originally Posted by Defiant View Post
Except, the "pulsing" isn't what drives the turbine. The turbine is driven by the heat energy.
No it doesn't. A difference in pressure is what makes a turbine, any turbine, spin. If you were to pipe high pressure, cold air into a turbo it would still work. Divided housing turbines have been around in large turbos for a long time, and they do work well. By dividing the runners you maintain a smaller, higher pressure area on the turbine wheel to do more efficient work. This is also why higher compression engines spool turbos faster.
Offline
[posts] Reply With Quote
Sponsored Links
