I'm working on the list for 2Gs slowly guys so please bare with me...
Suspension:
Front(AWD):
1990-1994:
-Axle Shaft Nut: 144-188 ft. lbs.
-Ball Joint Stud Nut: 43-52 ft. lbs.**
-Brake Caliper Bolt: 58-72 ft. lbs.
-Clamp-to-Cross-Member Nut/Bolt:
Bolts (short): 58-72 ft. lbs.**
Bolts (long #7 on bolt head): 58-72 ft. lbs.**
Bolts (long #10 on bolt head): 72-87 ft. lbs.**
Nut: 25-34 ft. lbs.**
-Control Arm-to-Cross-Member bolt: 72-87 ft. lbs.**
-Cross-Member Brace Bolt: 51-58 ft. lbs.
-Cross-Member #2 Rear Bolt: 58-72 ft. lbs.
-Cross-Member Bolt (left):
Front: 58-72 ft. lbs.
Rear: 51-58 ft. lbs.
-Stabilizer Bar Link Nut: 25-33 ft. lbs.
-Stabilizer Bar Mounting Bracket Bolt: 22-30 ft. lbs.
-Strut Shaft (Self-locking nut): 43-51 ft. lbs.
-Strut-To-Body Nut: 29-39 ft. lbs.
-Strut-To-Knuckle Bolt: 80-101 ft. lbs.
-Tie Rod Nut: 17-25 ft. lbs.
** Tighten to specs. with vehicle at normal operating height.
1995-:
-Axle Nut: 145-188 ft. lbs.
-Caliper Assembly Mounting Bolt: 65 ft. lbs.
-Center Member To Body: 58-65 ft. lbs.
-Compression Lower Arm To Cross-Member: 60 ft. lbs.
-Compression Lower Arm To Knuckle: 43-52 ft. lbs.
-Drive Shaft Nut: 145-188 ft. lbs.
-Dust Shield To Knuckle: 6.5 ft. lbs.
-Hub Assembly To Knuckle: 65 ft. lbs.
-Hub Nut: 145-188 ft. lbs.
-Joint Assembly & Gear Box Bolt:13 ft. lbs.
-Knuckle To Compression Lower Arm: 43-52 ft. lbs.
-Knuckle Upper Mounting: 21 ft. lbs.
-Lateral Lower Arm To Cross-Member: 71-85 ft. lbs.
-Lateral Lower Arm To Damper Fork: 65 ft. lbs.
-Lateral Lower Arm To Knuckle: 43-52 ft. lbs.
-Power Steering Brackets To Cross-Member: 51 ft. lbs.
-Power Steering Oil Pump To Bracket: 21-29 ft. lbs.
-Power Steering Pipe Connections: 11 ft. lbs.
-Power Steering Pressure Hose To Pump (Non-Turbo): 42 ft. lbs.
-Power Steering Pressure Hose to Pump (Turbo): 13 ft. lbs.
-Stabilizer Bar Bracket: 28 ft. lbs.
-Stabilizer Link To Stabilizer Bar: 28 ft. lbs.
-Stabilizer Link To Dampener Fork: 28 ft. lbs.
-Stay To Cross Member: 51-58 ft. lbs.
-Strut Top End Nut: 16 ft. lbs.
-Strut Lower Mounting: 75 ft. lbs.
-Strut Upper Mounting Nut: 32 ft. lbs.
-Tie Rod End To Knuckle: 21 ft. lbs.
-Upper Arm To Knuckle: 21 ft. lbs.
-Wheel Lug Nuts: 88-108 ft. lbs.
Rear(AWD):
1990-1994:
-Axle Shaft Companion Flange Nut-To- Rear: 116-159 ft. lbs.
-Ball Joint Nut: 43-52 ft. lbs.
-Brake Tube Bracket-To-Rear Shock Absorber: 12-19 ft. lbs.
-Companion Flange-To-Drive Shaft: 40-47 ft. lbs.
-Lower Arm Ball Joint To Knuckle: 43-52 ft.lbs.
-Hub Assy. To Knuckle: 144-188 ft. lbs.
-Joint Assy.: 11-16 ft. lbs.
-Lower Arm Clamp To Cross-Member (Bolt): 58-72 ft. lbs.
-Lower Arm Clamp To Cross-Member (Nut): 25-34 ft. lbs.
-Caliper Mounting Assy. Bolt: 58-72 ft. lbs.
-Center Bearing Bracket: 26-33 ft. lbs.
-Center Member To Body: 58-72 ft. lbs.
-Drive Shaft Nut: 144-189 ft. lbs.
-End Plug: 36-51 ft. lbs.
-Feed Tubes: 9-13 ft. lbs.
-Gearbox To Bracket To Cross-Member: 43-58 ft. lbs.
-Knuckle To Strut Assy. 80-101 ft. lbs.
-Lower Arm To Knuckle: 43-52 ft.lbs.
-Lower Arm To Cross-Member: 65-80 ft.lbs.
-Upper Arm To Cross-Member: 101-116 ft.lbs.
-Upper Arm To Knuckle: 43-52 ft.lbs.
-Cross-Member Bracket To Body: 51-61 ft.lbs.
-Cross-Member Bracket To Cross-Member: 80-94 ft.lbs.
-Shock Absorber Upper Mounting Nut: 29-36 ft.lbs.
-Shock Absorber Lower Mounting Nut: 58-72 ft.lbs.
-Strut Top-End Nut: 43-51 ft. lbs.
-Strut Upper Mounting Nut: 29-39 ft. lbs.
-Stabilizer Link To Stabilizer Bar: 25-33 ft.lbs.
-Stabilizer Bar Bracket: 22-30 ft. lbs.
-Stabilizer Link: 25-33 ft. lbs.
-Wheel Bearing Nut: 144-188 ft.lbs.
-Tie Rod End Ball Joint: 17-25 ft. lbs.
-Tie Rod End To Rack: 58-72 ft. lbs.
1995-:
Axle Nut: 145-148 ft. lbs.
Brake Caliper Assembly: 36-43 ft. lbs.
Differential Mounting Bracket To Cross Member: 72 ft. lbs.
Differential Mounting Bracket To Differential: 65 ft. lbs.
Differential Mount Support Bolts: 33 ft. lbs.
Lower Arm To Cross Member: 71 ft. lbs.
Lower Arm To Knuckle: 71-72 ft. lbs.
Lower Shock Absorber Mounting Bolt: 71-72 ft. lbs.
Piston Rod Tightening Nut: 16 ft. lbs.
Propeller Shaft To Differential: 22-25 ft. lbs.
Rear Hub To Knuckle: 54-65 ft. lbs.
Stabilizer Bar Mounting Bracket: 7-10 ft. lbs.
Stabilizer Link To Lower Arm: 28 ft. lbs.
Toe Control Arm To Cross Member: 50-56 ft. lbs.
Toe Control Arm To Knuckle: 20-21 ft. lbs.
Trailing Arm To Body: 99-114 ft. lbs.
Trailing Arm To Knuckle: 85-101 ft. lbs.
Upper Arm To Knuckle: 71 ft. lbs.
Upper Arm Bracket To Body: 28 ft. lbs.
Upper Arm Bracket To Upper Arm: 41 ft. lbs.
Upper Shock Absorber Mounting Nut: 32 ft. lbs.
Drive Shaft/U-joints:
1990-1994:
-Center Support Bearing Mount Nut: 22-29 ft. lbs.
-CV Joint Nut: 22-29 ft. lbs.
-Drive Shaft Companion Flange Nut: 116-159 ft. lbs.
-Drive Shaft-To-Differential Flange Nut: 22-25 ft. lbs.
-Drive Shaft Yoke Nut: 116-159 ft. lbs.
1995-:
Transfer Case:
1990-1994:
-Drain/Fill Plug: 22-26 ft. lbs.
-Driven Bevel Gear (Lock Nut): 103-118 ft. lbs.
-Extension Housing Bolt: 11-16 ft. lbs.
-Front Exhaust Pipe Mounting Bracket Bolt: 15-22 ft. lbs.
-Front Exhaust Pipe (Self-Locking Nut): 22-30 ft. lbs.
-Transfer Case Adapter Bolt: 26-31 ft. lbs.
-Transfer Side Cover Bolt: 26-31 ft. lbs.
-Transfer Case Assy. Mounting Bolt: 40-43 ft. lbs.
-Case Cover Bolt: 71-89
in. lbs.
1995-:
Auto Trans/Transaxle:
1990-1994:
-Sprang Rod Support: 15-19 ft. lbs.
-Tie Rod End To Knuckle: 17-25 ft. lbs.
-Transaxle Control Cable Adjusting Nut: 7-10 ft. lbs.
-Transaxle Control Cable To Body: 7-10 ft. lbs.
-Transaxle Mount Bracket To Transaxle: 43-58 ft. lbs.
-Transfer Lock-Nut: 145-166 ft. lbs.
-Pressure Check Plug: 6-7 ft. lbs.
-Pulse Generator: 7-9 ft. lbs.
-Pump Housing To Reaction Shaft Support: 7-9 ft. lbs.
-Selector Lever Assembly: 7-10 ft. lbs.
-Shift Lock Cable To Selector Lever Assembly: 3-4 ft. lbs.
-Speedometer Sleeve Locking Plate: 2-4 ft. lbs.
-End Clutch Cover: 5-6 ft. lbs.
-Hose Bracket: 2-4 ft. lbs.
-Inhibitor Switch: 7-9 ft. lbs.
-Lever Assembly To Bracket Assembly: 10-14 ft. lbs.
-Lock Plate: 26-32 ft. lbs.
-Manual Control Lever Nut: 13-15 ft. lbs.
-Manual Control Shaft Setscrew: 6-7 ft. lbs.
-One-Way Clutch Outer Race: 18-25 ft. lbs.
-Ball Joint To Knuckle: 43-52 ft. lbs.
-Bearing Retainer: 12-15 ft. lbs.
-Bell Housing Cover To Engine: 7-9 ft. lbs.
-Clamp To Body: 3-4 ft. lbs.
-Converter Housing: 14-16 ft. lbs.
-Drain Plug: 22-25 ft. lbs.
-Drive Plate To Converter: 34-38 ft. lbs.
1995-:
-Air Intake Hose Connections: 3 ft. lbs.
-Bell Housing Cover: 7-9 ft. lbs.
-Compression Arm Connection: 44-52 ft. lbs.
-Cross-Member To Body: 51-58 ft. lbs.
-Cross-Member To RH Stay: 51-58 ft. lbs.
-Cross-Member To Transaxle: 42 ft. lbs.
-Damper Fork to Lateral Lower Arm: 65 ft. lbs.
-Drive Plate Connecting Bolt: 33-38 ft. lbs.
-Lateral Lower Arm Connection: 44-52 ft. lbs.
-Mounting Bracket To Body: 51 ft. lbs.
-Mounting Bracket To Transaxle: 42 ft. lbs.
-Oil Level Gauge Bracket: 17 ft. lbs.
-Rear Roll Stopper Bracket: 51 ft. lbs.
-Stabilizer Link To Damper Fork: 29 ft. lbs.
-Starter Motor to Transaxle: 22 ft. lbs.
-Tie Rod End Nut: 18-25 ft. lbs.
-Torque Converter Connecting Bolt: 33-38 ft. lbs.
-Transaxle Control Cable Connection: 7 ft. lbs.
-Transaxle Lower Coupling Bolts: 35 ft. lbs.
-Transaxle Upper Coupling Bolts: 22-25 ft. lbs.
Brakes:
1990-1994:
-Backing Plate Bolts: 36-43 ft. lbs.
-Bleed Screws: 8-11 ft. lbs.
-Brake Booster To Dash: 18-25 ft. lbs.
-Brake Hose To Rear Caliper Banjo Bolt: 5-7 ft. lbs.
-Caliper Support To Front Axle: 58-72 ft. lbs.
-Caliper Support To Rear Axle: 36-43 ft. lbs.
-Master Cylinder To Brake Booster: 6-9 ft. lbs.
-Wheel Cylinder: 6-9 ft. lbs.
1995-1996:
Front:
-Bleed Screws: 5-7 ft. lbs.
-Caliper Guide & Lock Pins: 54 ft. lbs.
Rear:
-Brake Hose-To-Rear Caliper Banjo Bolt: 18-25 ft. lbs.
Rear MR45V & MR45S 20 ft.lb
MR58V 32 ft.lb
-Caliper Support-To-Rear Axle: 36-43 ft. lbs.
Clutch Pedal Assy.:
1990-1994:
-Clutch Pedal Bracket: 6-9 ft. lbs.
-Clutch Pedal Support Bracket: 6-9 ft. lbs.
-Clutch Pedal To Support Bracket: 14-18 ft. lbs.
1995-:
Clutch Slave Cylinder:
1990-1994:
-Clutch Release Cylinder: 11-16 ft. lbs.
-Clutch Tube Flare Nut: 9-12 ft. lbs.
1995-:
Computers/Control Systems/Sensors:
All Years:
-Coolant Temperature Switch: 22-29 ft. lbs.
-EGR Valve Mounting Bolt: 16 ft. lbs.
-EGR Temp. Sensor: 7.3-8.6 ft. lbs.
-Engine Coolant Temperature Sensor: 15-29 ft. lbs.
-ISC Servo Mounting Screws: 1.8-3.3 ft. lbs.
-TPS Mounting Screws: 1.1-1.8 ft. lbs.
-Stop Lamp Switch: 7-11 ft. lbs.
-Back-up Lamp Switch: 22-25 ft. lbs.
-Oil Level Gauge Mounting Bolt: 9-11 ft. lbs.
-Oil Pressure Gauge Unit: 6-9 ft. lbs.
-Crank Angle Sensor: 7-9 ft. lbs.
-O2 Sensor: 29-36 ft. lbs.
-Cooling Fan Switch: 8-18 ft. lbs.
1990-1994:
-Fuel Gauge Unit: 1.4-2.2 ft. lbs.
1995-:
-Fuel Gauge Unit (FWD): 1.8 ft. lbs.
-Fuel Gauge Unit (AWD): 36 ft. lbs.
Differential Assy.:
1990-1994:
-Hanger Installation Bolt: 7-11 ft. lbs.
-Hook Installation Bolt: 7-11 ft. lbs.
-Piston Rod Nut: 14-18 ft. lbs.
-Rear Brake Assembly Installation Bolt: 36-43 ft. lbs.
-Differential Support Member To Body: 80-94 ft. lbs.
-Differential Carrier To Differential Support Member: 58-72 ft. lbs.
-Differential Carrier To Propeller Shaft: 22-25 ft. lbs.
-Lateral Rod Mounting Nut (Body Side): 58-72 ft. lbs.
-Lateral Rod Mounting Nut (Axle Beam Side): 72-87 ft. lbs.
-Trailing Arm Mounting Bolt: 72-87 ft. lbs.
-Trailing Arm To Cross Member: 101-116 ft. lbs.
1995-
Exhaust:
1990-1994:
-Exhaust Pipe Clamp Bolt: 22-29 ft. lbs.
-Exhaust Pipe Support Bracket: 22-30 ft. lbs.
-Exhaust Pipe-to-Hanger: 7-11 ft. lbs.
-Exhaust-To-Manifold (N/T): 29-43 ft. lbs.
-Heat Shield-To-Manifold: 9-11 ft.lbs.
-Exhaust Manifold-To-Turbo: 40-47 ft. lbs.
-Exhaust Manifold-To-Head: 18-22 ft. lbs.
-O2-To-Turbo Studs: 29-43 ft. lbs.
1995-:
-Exhaust Manifold-To-Head: (small studs)20 ft. lbs. & (2 large outer studs) 21 ft. lbs.
Fuel Delivery/Air Induction:
1990-1994:
-Accelerator Cable Adjustment Bolts: 3-4 ft. lbs.
-Air Bypass Valve: 11-16 ft. lbs.
-Air Hoses (Hose Clamps): 3 ft. lbs.
-Air Pipe Mounting Bolts: 9-11 ft. lbs.
-Drain Plug: 11-14 ft. lbs.
-FPR Installation Bolts: 6-7 ft. lbs.
-Fuel Rail Installation Bolts: 7-9 ft. lbs.
-Ground Plate Mounting Screws: 1.5-2 ft. lbs.
-High Pressure Hose-To-Fuel Filter: 18-25 ft. lbs.
-High Pressure Hose-To-Fuel Rail: 3-4 ft. lbs.
-High Pressure Hose-To-Fuel Pump: 22-29 ft. lbs.
-Intercooler-To-Body: 9-11 ft. lbs.
-Main Pipe-To-Fuel Filter: 22-29 ft. lbs.
-Main Pipe-To-High Pressure Hose (FWD): 18-25 ft. lbs.
-Main Pipe-To-High Pressure Hose (AWD): 22-29 ft. lbs.
-Throttle Body Stay Mounting Nuts: 11-16 ft. lbs.
-Throttle Body-To-Surge Tank Bolts: 11-16 ft. lbs.
-Intake Manifold Mounting Bolt (M8): 11-14 ft. lbs.
-Intake Manifold Mounting Nut & Bolt (M10): 22-30 ft. lbs.
1995-:
-Intake Manifold To Head: 14 ft. lbs.
-Electric Fuel Pump: 1.8 ft. lbs.
Ignition:
1990-1994:
-Crank/Cam Position Sensor Mounting Nut: (TDC): 7.5-8.5 ft. lbs.
-Spark Plugs: 15-21 ft. lbs.
1995-:
Manual Trans./Transaxle:
1990-1994:
-Bearing Retainer Bolt: 11-15 ft. lbs.
-Bellhousing Cover: 7-9 ft. lbs.
-Fulcrum: 25-30 ft. lbs.
-Input Shaft Locknut: 102-115 ft. lbs.
-Poppet Plug: 43-52 ft. lbs.
-Rear Housing Cover Bolt: 11-15 ft. lbs.
-Restrict Ball Assembly: 11-15 ft. lbs.
-Stopper Bracket Bolt: 11-15 ft. lbs.
-Transaxle Bracket: 43-58 ft. lbs.
-Transaxle Case Tightening Bolt: 26-30 ft. lbs.
-Transfer Assembly Mounting Bolt: 40-43 ft. lbs.
1995-:
-Back-Up Lamp Switch: 22 ft. lbs.
-Bearing Retainer Bolt: 14 ft. lbs.
-Clutch Cover Assembly: 11-16 ft. lbs.
-Compression Lower Arm: 44-52 ft. lbs.
-Flywheel Bolts: 55 ft. lbs.
-Lower Arm Ball Joint To Knuckle: 44-52 ft. lbs.
-Poppet Plug: 27 ft. lbs.
-Rear Housing Cover Bolt: 14 ft. lbs.
-Restrict Ball Assembly: 24 ft. lbs.
-Shift & Select Cable To Transaxle: 11-16 ft. lbs.
-Speedometer Sleeve Bolt: 3 ft. lbs.
-Starter Motor Mounting Bolt: 40 ft. lbs.
-Stop Lamp Switch: 24 ft. lbs.
-Tie Rod End To Knuckle: 18-24 ft. lbs.
-Transaxle Case Tightening Bolt: 29 ft. lbs.
-Transaxle Mounting Bolt: 35 ft. lbs.
-Transfer Assembly Mounting Bolt: 40-44 ft. lbs.
Steering:
1990-1994:
-Power Steering Bracket: 25-33 ft. lbs.
-Air Bag Retaining Bolts (Driver): 4 ft. lbs.
-Steering Wheel Nut: 30 ft. lbs.
Manual Steering:
P/S:
1995-:
95 Steering Column
Cooling:
1990-1994:
-Radiator Upper Insulator: 7-10 ft. lbs.
-Water Pipe "A" Mounting Bolt: 7-9 ft. lbs.
-Water Pipe "A" To Turbo: 25-36 ft. lbs.
-Water Pipe "B" To Turbo: 25-36 ft. lbs.
-Water Pipe "B" To Water Inlet Pipe: 29-36 ft. lbs.
-Engine Cooler Pipe-To-Engine Front Case: 29-33 ft lbs.
-Water Banjo Bolt: 25-36 ft. lbs.
1995-:
Water Pump:
1990-1994:
-Water Outlet: 12-14 ft. lbs.
-Water Pipe-To-Engine: 10-14 ft. lbs.
-Water Pipe-To-Turbo: 25-36 ft. lbs.
-Water Pump Bolt (4T): 9-11 ft. lbs.
-Water Pump Bolt (7T): 14-20 ft. lbs.
-Water Pump Pulley: 6-7 ft. lbs.
1995-:
Misc. Engine:
1990-1994:
-Starter Motor: 20-25 ft. lbs.
-Wastegate Actuator: 7-9 ft. lbs.
-Check Valve (Turbo): 22-25 ft. lbs.
-Timing Belt Rear Cover: 7-9 ft. lbs.
-6-Bolt Connecting Rod Cap: 36-38 ft. lbs.
-Rocker Cover: 2-3 ft.lbs.
-Spark Plug Galley Cover: 2-3 ft. lbs.
-Balance Shaft Sprocket: 31-35 ft. lbs.
1995-:
Engine Internals:
All Years:
1990-1994:
-Crankshaft Main Bearing Caps: 51 ft. lbs.
1995-1999:
-Crankshaft Main Bearing Caps: 18 ft. lbs. +90*(1/4 turn)
-Camshaft Bearing Cap Bolt: 14-15 ft. lbs.
-Camshaft Sprocket: 65 ft. lbs.
-Connecting rod Bearing Cap: 14.5 ft. lbs. +90*(1/4 turn)
Engine Supports/Cross Members:
1990-1994:
-Left Engine Support Bracket: 22-30 ft. lbs.
-Engine Mount Bracket-To-Bracket Nut/Bolt: 12-19 ft. lbs.
-Center Member Install Bolt: 58-72 ft. lbs.
1995-:
Misc. Oil:
1990-1994:
-Oil Pump To Bracket: 25-33 ft. lbs.
-Oil Reservation Bracket Bolt: 7-10 ft. lbs.
-Oil Pipe-To-Turbo: 20-25 ft. lbs.
-Oil Return Line-To-Oil Pan (Turbo): 6-7 ft. lbs
-Oil Pipe-To-Engine (Turbo): 10-14 ft. lbs.
-Oil Screen Nut or Bolt: 11-16 ft. lbs.
-Oil Pump Sprocket: 36-43 ft. lbs.
-Pressure Hose To Oil Pump: 10-15 ft. lbs.
-Oil Pump Driven Gear: 25-29 ft. lbs.
-Front Case: 14-16 ft. lbs.
-Oil Filter Bracket: 11-16 ft. lbs.
-Engine Oil Cooler Mounting Nut: 6-9 ft. lbs.
-Oil Banjo Bolt: 20-25 ft. lbs.
-Oil Jets: 22-25 ft. lbs.
1995-:
Pulleys:
1990-1994:
-Crank Pulley: 14-22 ft. lbs.
-Auto Tensioner: 14-20 ft. lbs.
-Timing Belt tensioner pulley: 31-40 ft. lbs.
-Timing belt idle pulley: 25-30 ft.lbs.
1995-:
This is what I have added so far. It includes what has been posted above. I have added links to a couple new diagrams, and I will be making links to lots more diagrams that are in my Photobucket account...
Thanks for the kind words.
