View Single Post
Old 12-04-2007, 12:17 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #38 (permalink)
JayRolla Offline
Proven Member
JayRolla's Avatar
Tech Posts: 4,758
Classifieds Rating: 6
Reputation: JayRolla is extremely helpful and trustworthyJayRolla is extremely helpful and trustworthy
Quote:
Originally Posted by JrCRXHF View Post
you guys might want to watch your air fuel ratio cause it changes when you are on e85
"You may have already read that E85 has a different stoichometric air fuel ratio than gasoline's 14.7. The stoich AFR for E85 (at 85% Ethanol) is 9.76. The stoich value represents an ideal perfect burn of the fuel usually used at part throttle conditions. Full throttle conditions require a richer mixture than stoich to prevent the dreaded detonation, or pinging."
I would look at my air fuel ratio again before you have big problems i tune E85 with lamda for that reason.
Thats why you must have a wbo2 sensor installed at all times when running e85. Sometimes when the season changes the ethonal/gas mix will change to 75% not 85% like normal so yes you need to watch for that.
Also even if you do run a little lean on e85 the detonation characteristics are so good you wont even knock unless you run dangerously lean. If you run about 30% more fuel at wot than your gas tune that will give you a real good base afr.
My mechanic has been running e85 for more than a year now and has time to play with all types of afr's. He said the safest afr to make the best power is around a 11.1 afr from his experience.
