View Single Post
Old 10-28-2007, 05:39 PM   #2 (permalink)
tegster1
Proven Member
tegster1's Avatar
Region: Midwest
Classifieds Rating: (2)
Reputation: tegster1 is more helpful than not
Well you could buy one from the store if thats what you mean. But, I am assuming you are you looking for this:
Quoting DSMcrazy3, "Our cars are non turbo. So pressure in the manifold should not exceed 0. When we add a turbo to our car, and the pressure in the manifold rises to say, 8 psi, the sensor see's that and sends a stronger signal to the ECU. When the ECU see's that, as a safe precaution, it immediately cuts the fuel supply, so that it won't support the added air and aid in possibly blowing the motor.
Of course our motors can withstand 8 PSI, but from the factory, since there is already a turbo version of the 2g Eclipse, they figure, "why would anyone who buys a non turbo eclipse turbo it?" So when the MAP see's that pressure it won't think, "oh, this person turbo'd their car and..well, it's ok" So again, fuel is cut."
You can buy something called a FCD. This will eliminate this problem. Send a message to VelocitaPaola and he can help you out with that.
P.S. You might want to fill out your profile so everyone knows what you have.
Offline
[posts] [gallery] [blogs] Reply With Quote
Sponsored Links
