View Single Post
Old 10-22-2007, 10:01 PM   #20 (permalink)
1fastlaser
Proven Member
1fastlaser's Avatar
Region: Tri State
Classifieds Rating: (2)
Reputation: 1fastlaser is an unknown
Quote:
Originally Posted by InfiniteGSX View Post
1fastlaser, I'm sorry to say... Look at that K Member... and then put it next to that truck frame. Very Different! Looks like the K Member was a quickie! That Truck frame has all the nessecary support comming from all angles. That K Member doesn't. It isn't that were doubting the mans previous jobs. But If you look at how suspensions get damaged, before you build something like that... you will know that peice looks very brittle. It looks very flimsy on the bottom side... which is why I mentioned a VBrace, and a X Brace, which in the end, would look like that truck suspension, and probably wouldn't break or bend if you dropped the car off of a plane.
Its exactly like LSD Said, If it does break... your not going to have much time to react before total destruction... and you, or someone else could get hurt. I'd feel safer knowing that I spent some extra time adding a little more brace to it. It doesn't take very long to pull the motor out of these cars, I say pull the motor on a friday night, spend all of saturday building around the steering box and I'm sure you guys have some tools you could put pressure on the bar itself, to see how it reacts.
BTW, don't take this post as me putting you or your guy down. Just would rather be safe then sorry. We really dont want to see anyone get hurt.
Well im not gonna argue, all is understood. It wasnt a quickie by any means. Look at his work, he knows his stuff and has built plenty of race cars, including 1/2 ton domestics- 3500 frame dropped turbo diesal trucks with 650hp and 1000 ft lbs of torque doing full out custom front suspension mounts and all (like the one at his shop now, thing is fast!) He spent two weeks on it. The pipes used have a thick inside diameter. You can look at it but you have to understand the stock used to build it. He knows chassis, and im great friends with him. I dont doubt his abilities.
Online
Sponsored Links
