Thread: keydiver/afc
View Single Post
Old 10-15-2007, 06:38 PM   #12 (permalink)
DGajre777
DSM Wiseman
DGajre777's Avatar
Region: Southeast
Classifieds Rating: (14)
Quote:
Originally Posted by erald01 View Post
the thing is that i have a dsm link also but i wanted to run it with the keydiver chip till i get used to the dsm link, but i did burn the boost gauge as the knock sum but i have no idea what the knock sum is all about can some one explain it briefly..
You do know that you can't run the keydiver chip and DSMLink at the same time, right?
Knock sum - On DSM's, the gauge will normally rest on the "-7", for 0 knock sum. It will rise 5 knock sum per division on the gauge, so "0"=5 knock sum, "+7"=10 knock sum, and "+14"=15 or more knock sum.
You want to see knocksum less than 5, which is basically between the first and second line (knock sum of 0-5) on the stock boost gauge coded to see knock sum. When you start to pull timing, you'll normally see knock (retard). 2Gs and 1Gs will retard 1 degree of timing (knock retard) for about 3 knock sum.
More info here - knock what is a sfe knock and what would be a bad knock?
There was a thread somewhere about how the knock sum on DSMchips.com website was wrong, but I can't find that thread anywhere.
____________________________
Dee.
Offline
