93laserAWD
- 48
- Sep 7, 2006
st. louis,
Missouri
boost gauge reads -10 inches at idle ( 850-900 rpm )
all fuel trims with 4-5 % all the time
no vacumm leaks
boost tested = everything good
full boost (13 pounds) at just above 3300 rpm
doesnt feel like the same car after timing belt install. I looked at the teeth and the are so so so close, but the exhaust side is just barely above intake. looks like 1/4 tooth off. head warped? block warp? any suggestions welcomed
no vacumm leaks
