View Single Post
Old 08-25-2007, 11:23 AM   #4 (permalink)
boostenon114
Proven Member
boostenon114's Avatar
Region: Tri State
Classifieds Rating: (0)
Reputation: boostenon114 is an unknown
Quote:
Originally Posted by hpram99 View Post
Yes, replacing the power steering pump is a 1 hour job.
Drain PS fluid.
Remove the belt.
Remove the low-pressure feed hose (bottom/side hose) from pump
Remove the high-pressure hose, making note of the order of washer, crush washers, and nut. Throw out the O-rings
Unplug Pressure Switch.
Remove the 5 bolts from the mount/PS pump
reinstall is reverse of removal
You'll need to re-tourqe them down to 21 ft/lbs, the adjustment bolt (long, skinny) is 16 ft/lbs.
No that is knowing your stuff right there!
Offline
Sponsored Links
