joining the DSMLINK bandwagon! :)
c4uldr0n
390
Oct 21, 2006
Superior, Wisconsin
After I got my 650cc injectors, I was able to tune them with MAF-T... but not 110% like I would like. Thanks to JNZTUNING, I should have my DSMLINK just in time for my magnus intake and hks 264/272 cams early next week. woohoo!
/excitement
c4uldr0n
GO TO #6 FOR TECH QUESTION
Hahah nice!!! I'm getting DSMlink in today or tomorrow, I'm so stoked! JUST in time for the shootout :) It'll be my first time at a dyno on Friday :)
This weekend is going to be the best.
I run blow through... and don't want to fab my piping again (I bought if from you LAN-, still working good)... I should be able to ZERO OUT my GM MAF and let DSMLINK do the rest!
If my GM MAF doesn't work out, is it easy to alter DSMLINK to use 2G maf opposed to 1G maf/GM MAF
Yes you can or you can calibrate your maft using a wideband.
The point of my previous post was to for you to post a thread like this in the hangout next time since there were no tech questions in your original post.
gotcha buddy... I'm going to try the GM MAF-T + Wideband (AEM UEGO), and if that didn't work as planned I was going to do 2G MAF since I doubt I'll surpass it's limits with a 50 trim in the future
I'm running 3065 with a 2G mas, you will find a 2G mas (unhacked) to be much more consistent therefore tuner friendlier than a maft, this is not to say maft can't be made accurate if it's properly calibrated. With "fake MAF" function in DSMLink, you no longer have to worry about maxing out the 2G mas anyway.
