View Single Post
Old 07-18-2007, 03:47 PM   #68 (permalink)
IPT
Proven Member
Classifieds Rating: (0)
Reputation: IPT is more helpful than not
Green lines are an S362 in a .85 T3 turbine housing @ 38psi
Blue lines are an SC61 @32 psi (this is all the turbo would put out)
Before some one starts yelling about the different boost pressures. The S362 @ 38psi of boost had 18 degree cooler intake temps then the SC61 did @ 32psi. Also 32psi is all that the SC61 would make on this setup.
This was on a fully built SRT4 with a cast log style manifold.
Offline
Sponsored Links
