externals are better, and you can run an FP Green with the manifold off the o2 housing, you just need the right o2 setup (not stock stuff). Running your wastegate off the #1 runner is not ideal.
I'd run a green with the gate off of the o2 with the FP manifold, unless the price is pretty close, and then i'd step up to the FP3052 in the same config.
____________________________
-andrew
