2.4L cam choices
jpbrazill
151
2
Dec 27, 2003
Castle Rock, Colorado
I have had a 2.4L in my 1G for awhile now. I have recently dropped in a set of 101200s. I didnt really notice any difference at the dyno. Since then, I had the head machined for 1mm OS valves, and have aquired some BC 280s. Have any of you ran BC 280s with a 2.3 or 2.4? Have any of you ran the 101200s with good results? Thanks
J.P.
I'm building my stroker with 101200s - I can post results in a week or so.
The only thing I'd be worried about is that I think that 280's would push your power band a little too high maybe? Correct me If I'm wrong but I thought those cams are more designed to run @ 4000-8500ish...
Maybe I'm a wuss.. But I'd only probably rev mine to 7500 max. meh? What are your thoughts?
The 2.3/2.4 will move the 280's power range lower due to the increased air flow at the same rpm with the 2.0. The best way to decide where to rev to is by putting your car on a dyno. Picking a number out of thin air because alot of people suggest that is not best for your set up.
That makes more sense. Not everyone has access to an AWD dyno, so some do have to go off other peoples results with similar setups.
Do you have any numbers of how far the 280's range is moved down? Just out of curiosity? I wonder if I should go with bigger cams....
101200's/Fp2's are a waste on a 100mm stroke engine. Get something that was designed for your engine, Comp and Crane both make cams for your application. I would give them a call or check out the FP stroker cams.
Here's a back to back comparison of the FP2's and FP3's. The 3x's would probably give bigger power gains.
http://www.dsmtuners.com/forums/showthread.php?t=183700&highlight=fp2
Unfortunately, I have already looked into getting a set of FP3's or 3x's. In order to use the 3's and 3x's, you have to use their springs and retainers. THe acceleration ramps for the cams and the amount of lift is beyond even the BC springs and retainers. I have SI dual springs and ti retainers which only have so much seat pressure and open seat pressure. They don't have nearly enough pressure that the FP springs and retainers do.
So, I will be looking at cams that are not so aggressive for now.
Do you have any particular opinion on BC 280s on a stroker?
J.P.
i had choose to run 272s, had been told by more than a few that 280s would be to much for a streetable car. but 2.3l/2.4l would make sense to lower the range of the 280s.
def sounds like a better idea now that i think about it and it makes more sense to me.
He didn't say they were stock, he said they were for stock 2.0, as in stock displacement 2.0 engine's, not 2.3/2.4's.
So You're staying my stock 2.0 has/had comp101200s? then what are comp 101100s? A down grade?
It's an aftermarket cam that's more aggressive than the stock cam in a 2.0. The cams are NOT stock by any means... How would that make any sense?
I understand that they might not be MUCH of an improvement in the 2.4L but they should net SOME gains, over STOCK 2.0 Cams - which there have been dyno charts to prove that.
COMP101200
Duration
259 Intake
258 Exhaust
STOCK TURBO cams
Duration
252 Intake
244 Exhaust
http://dsmtuners.com/forums/showthread.php?t=17110
It might not be much of an upgrade but it's not stock. I know there is more to a cam than just duration, however, I don't have the time to dig through the threads to prove that they're not stock. period. Duration is one example.
COMP101200
Duration
259 Intake
258 Exhaust
STOCK TURBO cams
Duration
252 Intake
244 Exhaust
I think he was just referring to the displacement. You would see the most gain from a 2.0 than a stroker. Comp cams claims that the 101200s net you 35hp out of the box...hmm
J.P.
COMP101200
Duration
259 Intake
258 Exhaust
STOCK TURBO cams
Duration
252 Intake
244 Exhaust
You miss read the origional post you commented on & then missread GVR4592's post in reply. Nether said the 200's were the stock cam that came with the car. They were simply saying that this aftermarket cam was designed to run in a stock displacement motor (ie 2.0L) & isn't the preferred cam upgrade for someone running a stroker, such as the origional poster.
I installed FP2's (101200's) after my 2.4 swap. I wish I had gone with FP3X's but i was very happy with the results. I gained airflow over the entire RPM band which was suprising; I was only expecting gains up top.
The FPxX cams were designed for stroked motors. The extra lift is critical for stroked motors. I suggest getting bigger cams.
Acually, the fp3 and fp3x were "designed" for stroker motors. The x series are higher ramp rate (and lift) cams, and higher ramp rate benefits everyone.
Talking to Robert he suggested fp2x for my stroker with mild needs (fp3052).
Not comes the interesting part. I finally figured out how to compare cam profiles on fp's site. Open up two browsers, maximize both, and open the profile graphs of the two cams you want to compare. Then alt-tab quickly between the two browsers and look for differences. The first version with the lobes centered is good for looking at the overall area under the curve, ramp rate, etc. The second one with the 720 degree view is good for looking at lobe center line, ie; advance/retard.
Sorry, now comes the interesting part.
The fp2x and fp3 are basically the same profile except the fp3 actually has lower max lift. In other words the fp2x has the same or higher lift than the fp3 everywhere except in the low lift regions (maybe the quicker ramp in the low lift regions does have some benefit for strokers). Looking at the 720 degree graphs you notice that the intake cam on the fp3 is a couple of degrees advanced compared to the 2x. And that's as far as the differences go.
In other words, I'm glad I got the fp2x's. I actually have higher lift, same ramp, and since I have adjustable cam gears I can always replicate the lobe centerline of the fp3 if it turns out to be beneficial.
Now I gotta get out there and install the suckers.
PS: If you buy Supertech dual springs they come with the slim valve seals, so you don't have to buy them separately. I have a spare set sitting around now cause I didnt know this.
This is exactly what I was going to post. Thank you for mentioning this. See my thread for more details about these cams: FP2Xs and 10,000 rpms. To get great stroker cams, an adjustable cam gear is all thats needed for me to get stroker cams when/if I decide to stroke my setup.
Here's an overlay of one the two cam profiles:
Note the FP2X cams have slightly higher lift. Adjusting the intake cam timing is all that is neccesary to turn fp2Xs into stroker fp3s w/ more peak lift. Advancing it increases overlap (helps spool and midrange torque) and optimises timing for lower rpm cylinder filling.
Goddamnit, I should've gotten the 3x's. Looks like again it's the same profile as the 2x with higher lift, and different center lines. Duration is the same. The only reason I didn't go with the biggest cams was to be able to pass emissions, but it looks like the 3x would've passed just as easily as the 2x with some cam timing tweaks. Live and learn...
Well. Considering the peak lift. I would think that you would go to dual springs (much more money). My manleys cost half and handle the 2X profile jsut fine to 8500 rpms. Since peak lift really does have an affect on the neccesary spring rate as much as ramp rate, I would suspect that valve float would be quite an issue.
I did talk to Manley tech for 30 minutes on the phone about their springs. According to them, their 4g63 springs, like all their other springs on the market, are quite over engineered (on purpose like everyone else). So their advertized spring rates are quite conservative and not indicative of what they can handle. But they seam to put a bit more overkill than other companies. Several techs have suggested just shimming these springs for caution to take such a cam profile to over 9K. Now considering the 2X has a lower lift but I have heavy STOCK retainers, I don't see why you couldn't take 3X cams to 7500 w/ these springs and a good set of shims from your local machine shop for cheap. BUT! this is not using all the potential of the 3x that the duration and the 2x profile suggests.
Making the cams lazy (retarding both or taking out the overlap), will cause almost any cam to "pass emissions".
I said "doh" cause I already got Supertech dual springs. I had valvetrain issues that required me to take a spring off anyway, and at that point I decided to redo everything the way I should have in the first place if I had the money at the time. Wanted to get rid of my regrinds and 15 year old springs. So now a grand later I have my fp2x's in there :)
I got the ST springs with ti retainers and slim seals for 310 plus shipping, very close to the price I would've paid for any brand. These mofos are rated at 110lb seat pressure and 310lb open pressure. I'm sure they would've handled 3x's on my low revving stroker.
Now my only worry is if these crazy springs are gonna destroy the journals in my head :)
on my G4CS I'm running a set of FP3's with a FP HTA35R, Talked to both Robert and with Scott at FP and both suggested just running the FP3's at least for my 2.4L and 35R application. Was interested in the new FP4R's as a possible candidate but was told the 3's would be a better option.
As per Robert the FP3X's are only when you are running at least a 75-80 lb/min turbo.
I went with the new DSM EVO9 beehive spring retainer combo after talking with Scott the other day, He figures with me running an auto trans(no chance of mis-shift issues) taking the stroker up to 8K with the FP3's and the EVO9 spring retainer combo should be fine for spring pressures and lift clearance.
I would recommend the FP3's for the stroker.
Interesting thread!
I'm diggin your setup DSMMACK... Not that much different then mine... I'd love you see some pics of your W2A setup!
I've been running the Comp 101200's in my 2.4L 4G64 conversion and I'm now considering a set of those FP3's myself.
  • Wanted 1g Wanted - 91-94 1g Throttle Body or replacement shaft + plate
    Looking to replace a TB with a complete 91-94 or replace TB shaft + plate. Let me know!
    • athlete3344
  • For sale 1g 90 Oil Cooler
