What is your torque converter slippage?? Formula inside.
Car Cannibal
688
164
Jun 7, 2003
Chicago, Illinois
Looking to see who is making an efficient converter to buy from. Here is the formula to figure out your converter slippage.
GEAR X MPH X 336= ???/ TIRE HEIGHT = Zero slippage
Example
4.10 x 122 x 366 = 183073.2/24.5 = 7472 ( zero slippage )
If at the race track your true rpm through the traps was 7950 then divide the two
7472/7950 = .939
Your converter is slipping 6%. 3-6% is generally really good on a non lock up converter.
Keep in mind that your tire diameter/height grows by a nonzero amount by the time you hit the traps, especially if you're running slicks, and doubly so if you're actually hitting the traps at decent speeds.
Some race slicks can get 20% (!) more diameter at the end of the track versus sitting static at the starting line.
If you're running street tires though, this formula will get you quite close.
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a thermostat housing
    Oem thermostat housing 420a $20 + shipping + fees.
    • Stizzydrew
  • For sale 420A NVG T350
    New venture gear T350 M/T 420a
    • Stizzydrew
