adrian2627
- 143
- 4
- Jul 13, 2005
Hattiesburg,
Mississippi
---Sorry for the long post--Hi, I just recently acquired a maft setup for free from a friend. I have keydiver stage 3 and an afc to fine tune. I set my translator to all zeroes except for the injector compensation, i set it to 450 for factory, i already have the chip compesating for my 560's. Now, ever since i installed the maft, i have little to no power at all. i connected my logger and i dont even see my timing go up, it stays around 8-11 max. I tried tuning with afc by richening or leaning the mixture but i get high knock either way. Maybe im not doing it right or something. my 1000 rpm trim was around +17 so i had to take out -12/14 on the safc, i did that for 1000, 2000, and 3000 then carried 3000 all the way on the low trims. I left the high alone for now since like i said, im only using the translator to vent thats it. Still no power, no timing, and knock like a mofo. So today i said screw it and put my old setup back(2g mas), and zeroed out the afc since i have the chip. Now on part throttle around 4-5th gear under load, i see my knocksum gauge rising almost pegged. I reset the ecu by disconnecting the negative terminal for about 5 mins. What is going on? any help/ suggestion would be appreciated. thank you
