Hey guys, I've already used the search function and read through a couple threads. I also went to the
vfaq page for upgrading brakes.
My question is has anyone actually used the brakes from a 92'-96' Diamante. Do the calipers have the same part number as the 93+ dual piston calipers. If so, I'm assuming that the mounting brackets from the Diamante should also be compatible with a 1G. Can anyone tell me if this is true?
If so, I know it will be a lot cheaper to get a set of used Diamante Calipers ($30 a pair) vs. ($100-$150) a pair for DSM dual piston calipers.
Thanks in advance.
