View Single Post
Old 12-09-2004, 01:57 PM   #17 (permalink)
blcknspo0ln
DSM Wiseman
blcknspo0ln's Avatar
Region: Tri State
Classifieds Rating: (4)
okay, thanks to your guys help i've bumped my timing up to 16 at around 6.2k , 3rd gear pull.
i was doing a little more research and apparently 16* timing is STILL not at optimum efficiency. i think i'm supposed to ahve 20-21* right?
lastly, should i log air flow rates when logging? it was mentioned that too high an air flow rate will result in pulled timing. if this is true, how do you adjust that setting? should i lean it out a little more and see if the hz goes down?
____________________________
~Tom
Offline
[posts] [gallery] [blogs] Reply With Quote
Sponsored Links
