According to the MSD tech I talked to, all you need to do to run the DIS-2 coilpacks on a stock ignition is the adapter (P/N 8912), though you'll probably also want to grab the coil interface blocks. If you're running it right off the MSD ignition controller, you can skip Pn 8912 and just go with the interface blocks for easier wiring hookup.
