Build your own SS oil feed line
After many searches on this board and seeing lots of posts on this but never an answer with the sizes I will let you know what you need.
-3 an SS line about 2 1/2' with a swivel on both ends so when you tighten it the line doesn't get a big twist in it.
Now the filter housing uses a 3/8 npt plug which you reduce to 1/8 npt one side and the an fitting on the other.
The only differance I see right now with the turbo connection is that the 14b uses a banjo so you may need to take it with you to the place you get the hose to adapt it.
For my precision t3/t4 all it uses is a 1/8 npt to AN fitting. I used a 90* here to bring it out the front of my turbo to the filter housing.
Hope this helps I will post some pics later.
Just some pictures of the fittings I used. Now these dump to AN fittings so now you need the fitting to go from AN to npt here is where you can fill in what you need.
