Galipso - 97 Talon FWD TSI
- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Eagle Talon TSi
- Turbo Type
- 16g
- Drivetrain
- FWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Full Body Kit with shaved body
Auto-Loc Door Poppers
Suncoast Creation Single Scoop Ram Air Hood
FMIC
Genuine "MHI" Mitsubishi TD05H "EVO III Big" 16G (49178-01470)
Fuel Lab 515 FPR
Walbro 255
Fuel Pump Rewired,
Aluminum radiator with slim fans
3" Megan Racing Downpipe and Cat-back Exhaust
- Mods-Engine
- 6 bolt block bored 20 over
Eagle Rods
Wiseco Pistons
Crank was rebalanced
950cc Injectors
Balance Shaft Elim Kit
Kiggly Crank Trigger Sensor
Kiggly HLA High Pressure Regulator
Rebuilt 2G OEM head:
GSC Power Division Intake Valve Guides with Depth Stopper
GSC Power Division Exhaust Valve Guides with Depth Stopper
Topline Viton Valve Seals
Topline Revised Lifter
Ferrea Valve Locks
Brian Crower Camshafts & Valve Springs/Retainers Combo: Camshaft Profile 268/272 Degrees
AEM Tru-Time Cam Gears
GSC Power Division Exhaust Valves 30.5mm (STD)
GSC Power Division Intake Valves 34mm (STD)
1G black top CAS
Powder coated components in Bentley Blue
- Mods-EMS & Logging
- Auto-Meter gauges
Turbo Timer
ECMLink V3
Innovative MTX-L Wideband O2
- Mods-Drivetrain
- Fidanza Flywheel
Southbend Ceramic Clutch
Southbend SS Pressure Plate
Competition Clutch Fork
SS clutch line from Master to Slave
Torque Solutions Shifter Bushings
Ebay short throw shifter
- Mods-Handling
- 18" Rims in Black Chrome
235/40/R18 Performance Tires
Drilled and Slotted Rotors
Megan Racing Street Series Coilovers
- Parts Wishlist
- A paint job, but really i just want it to run at this point!
- Background
- Car's name is Galipso - named after pulling parts from a Galant, Talon and Eclipse. I bought her off a street racer who did an excellent demo with it in Detroit, but after i bought it, i found out how hacked and shitty the whole car was put together. I blew the tranny first, then the clutch, then the head, then finally spun a bearing. Now im rebuilding from the block out and am trying to do everything the right way the best i can with help from the DSMtuners.com community
