BIRDCLAWTSi's Talon TSi AWD
Eagle Talon TSi AWD
Build Type
  1. Street
Forced Performance race manifold,,
Megan Racing 02 Housing(Modified for external gate),,
Knockoff Tial 38mm Wastegate,,
Buschur racing 2.5" Downpipe,,
Vibrant Stainless cat,,
Buschur 2.5"Cat back,,
Forced Performance 4" intake ,,
PTE 680's @ 50 psi,,
Supra MKIV 1020 300 Lph pump(Rewired),,
FUELAB 515 1:1 Regulator,,
FUELAB 818 Filter/Feed Upgrade,,
NGK Wires,,
NGK BR7ES (.024"),,
JM FAB Coil relocation bracket,,
GREDDY Type S BOV,,
Punishment racing FMIC,,
Prothane Urethane motor mounts,,
Mishimoto aluminum radiator,,
Mods-Engine
Billet Wheel 7 Blade HX35,,
BEP .55 A/R Bolt on,,
2.3L 6 Bolt 4G63,,
WISECO 86mm 8.8:1 Stroker Pistons,,
Eagle H-Beam rods,,
Eagle 100mm crank,,
ACL Race Bearings(Rod/Mains),,
Balance Shafts Re-Installed<-- I Love Them,,
Fluidamper Crankshaft Damper,,
2g Head/Intake Manifold(Ported for 1G Throttle body),,
DKS 2's 272/272 cams,,
Supertech valves,,
Supertech stemseals,,
BC1100 springs & Retainers,,
3G revised lifters,,
ARP head studs/Main studs/Rod bolts/Cam gear bolts,,
Fel-Pro permatorque head gasket,,
BC Adjustable cam gears,,
Mods-EMS & Logging
ECMLink V3 Speed density,,
GM IAT,,
Omni 4 BAR Map,,
Snow Performance water/Meth Injection/625ml/min nozzle/60/40 Meth/Water ,,
MAC Boost solenoid,,
INNOVATE LC-1 Wideband(G2 Gauge),,
AEM Digital BOOST gauge,,
AEM Digital OIL Pressure gauge,,
Mods-Drivetrain
Competition Clutch Stage 4 Pressure Plate,,ACT Street Disc,,
Stock Flywheel<-- Nice and Heay,,
Redline MT-90 in Tranny,,Redline heavy in Transfer case and Diff.l
Megan Racing springs,,
KYB AGX struts,, <--(Terrible suspension setup, Do not recommend,Sits nice, Rides like shit..)
25MM suspension tech. Rear sway bar,,
Energy Front sway bar bushings,,
Front and rear ebay strut bars,,
Energy suspension control arm bushings, Front and rear,,
Whiteline caster bushings on front control arms,,
Whiteline front camber kit,,
Welded Washer rear toe eliminator,,
Prothane subframe bushings,,
Continental ExtremeContact DWS 205/55/ZR16,,
1/8 Mile E/T
8.948
1/8 Mile MPH
76.680
258.0 lb/ft
BIRDCLAWTSi
Share this Vehicle
