ECMlink Holset HX35W Dyno. Stock Head/Block. 606 AWHP
NordicSaab
198
26
Oct 6, 2011
Tampa, Florida
Just re-dynoed the car. Dyno sheet attached.
Car was tuned at Tucker Performance, Palmetto, FL:
https://www.facebook.com/pages/Tucker-Performance/207528792764321
https://plus.google.com/105995112585095661413/about?gl=us&hl=en
Video is on the FB page if interested.
Mod List:
Holset HX35W (Stock Housing) 7 Blade
ID 2000 Injectors
Hawver Intake Manifold
Kiggley Racing Valve Springs
ARP Exhaust Studs
ARP HeadStuds
Extended Wheels Studs
Unorthodox Underdrive Pulleys
NGR BOV
Custom Radiator Overflow Tank
Relocated Lower Radiator Support
Jay Racing Alternator Relocation
2.75" Aluminum Intke Piping
Aluminum Radiator
Custom Aluminum Fan Shroud
x2 12" Spal Fans
3" Custom Downpipe
3" Downpipe Back Exhaust (No Muffler, No Cat)
Large FMIC
DSM Link V3
Speed Density
JMF 7 Gallon Fuel Cell
Walbro 455
Aeromotive FPR
Aeromotive Inline Filter
Stainless Steel Fuel lines
AN Fitting on OEM Fuel Rail
17" Evo Enkei Wheels
Hankook RS-3 Street Tires
17" Mustang Cobra Replica 17x10 wheels
Kumho XS 295/40/17 Tires
Pirelli Race Slicks
Brass Shifter Bushings
Aluminum Drive Shaft Bushings
Aluminum Shifter Bushings
Urethane Engine Inserts
BulFab Front Engine Mount Bar
Gutted Interior
4 Point Cage
Removable Lexan Side Windows
ACT Stage 3 Clutch
Hawk Blue Race Pads
Corbeau FX1 Race Seat
Custom Made Seat Mount
BC Custom Coil Over Suspension
Race Seat Back Brace to Cage
Momo Steering Wheel
13" Mustang Cobra Big Brake Kit
Any boost plots?
RPM (rpm) BoostEst (-inHg/+psi)
2490 -6.5
2493 -3.6
2498 -1.6
2495 -1.7
2518 -1.3
2520 -1.7
2539 -1.8
2532 -1.9
2553 -1.5
2549 -1.5
2572 -1.3
2567 -1.3
2579 -1.3
2593 -1.3
2604 -1.2
2606 -0.9
2617 -0.7
2628 -0.9
2630 -0.7
2643 -0.7
2661 -0.7
2658 -0.5
2667 -0.5
2679 -0.7
2690 -0.5
2706 -0.1
2710 -0.1
2725 0
2727 -0.1
2743 -0.1
2751 0
2763 0
2772 -0.1
2780 0
2792 0.2
2803 0.3
2811 0.4
2834 0.3
2830 0.4
2854 0.4
2867 0.7
2863 0.7
2885 0.7
2880 0.8
2905 1
2914 1
2937 0.9
2932 1.2
2941 1.2
2969 1.2
2962 1.3
2971 1.5
2988 1.5
3010 1.5
3012 1.5
3041 1.5
3051 1.4
3064 1.6
3074 1.6
3079 1.6
3092 1.6
3099 1.8
3112 1.6
3143 1.8
3151 1.9
3170 1.9
3178 2
3208 2
3205 2
3227 2.2
3222 2
3236 2.2
3247 2.2
3255 2.2
3269 2.4
3298 2.3
3310 2.5
3327 2.3
3330 2.5
3354 2.5
3375 2.4
3378 2.6
3388 2.6
3425 2.6
3453 2.8
3431 2.8
3505 2.7
3463 3
3524 3
3511 3
3475 3.2
3561 3.2
3613 3.4
3616 3.4
3595 3.7
3616 3.6
3627 3.9
3676 3.9
3695 4.1
3720 4.1
3750 4.1
3717 4.4
3780 4.4
3807 4.6
3792 4.8
3796 5
3854 5
3886 5.3
3882 5.2
3906 5.6
3939 5.8
3968 6
3964 6
4028 6.2
4028 6.4
4063 6.6
4054 6.9
4144 7.1
4195 7.3
4148 7.5
4176 7.9
4228 8.2
4305 8.3
4296 9.2
4325 9.5
4386 9.9
4350 10.3
4407 10.8
4438 11
4529 11.5
4475 11.9
4590 12.4
4596 12.9
4641 13.5
4723 14.2
4795 14.7
4832 15.6
4777 16.8
4883 17.8
4960 18.9
4987 19.9
5040 20.8
5088 21.7
5123 22.9
5216 23.9
5297 24.8
5403 25.4
5523 26.8
5605 27.7
5665 28.8
5716 29.9
5832 31.3
5896 31.8
5981 32.5
6048 32.8
6168 33.5
6250 33.8
6477 34.1
6510 34.6
6614 36.1
6684 37.1
6757 38.3
6906 38.2
7009 39.4
6932 40.2
6983 39.7
6996 39.9
7116 40.2
7253 40.4
7170 40.2
7310 39.5
7353 40.7
7396 41
7396 40.3
7426 40.7
7606 40.7
7669 40.8
7669 41.2
7748 40.8
7812 40.3
7911 41.3
7962 41.3
7928 41.5
7979 41.5
7962 41
8099 41
8260 41.5
8170 41.5
8352 41.3
8371 41
8224 41.1
8389 40.3
8523 40.3
8260 40.6
8523 40.3
8681 39.6
Awesome, thank you, I appreciate you posting the boost log. Im impressed that you did this with stock cams as well!
x2. Also what exhaust manifold do you have? It looks like your average open T3 manifold in the dyno video but it's hard to tell.
This is where my setup is odd. It is the stock t3 divided holset housing, internally gated, connected to a cheap ebay open t3 manifold. I bought the eBay manifold to chop up for a mock but it fit without any modification. I fully expect this manifold to fall apart and, at that time, I will rebuild with better materials.
To be clear, I maintained the stock internal wastegate. This was accomplished by shifting the wastegate mounting points and notching the lower radiator support to shift the radiator out. This freed up another inch of room , between the engine and radiator.
Why does it hit 30 psi by 5800....... Thats slower than my hx40 was..... I saw 38psi by 5800 67lb/min.. Seems weird. You didn't hit 38psi until 6900, what gear was the pull done in?
Might be the result of divided housing and open manifold.
Great results for a very simple setup and even stock cams!
He's on stock cams. How much faster would you expect it to spool?
Yeah a 12cm housing is pretty big and it makes them laggy. Although that seems worse than I'd expect. Perhaps there's a bit of creep going on.
That's what I was thinking. Either due to boost controller settings, the wastegate not being fully seated, or blowing open. What really makes me think something is wrong with the wastegate setup is the 1,000 Rpms it takes to get from 30 to 40 psi. That's the beauty of an external wastegate, you know when it cracks open.
I think mine had about 30psi at 5000 or so, it's been 4 years since I ran that setup though
My car has a similar behavior, but I do it with ecu controlled boost to keep the torque down and help the trans live. Isn't working so fat :(
Did nobody else notice the 40 psi on stock motor part:hellyeah:? I've had mine spike there a few times but I never considered actually running it that high. Also I'm surprised you didn't have knock issues with the stock cams. I couldn't get over 17* of timing on e85 before cams at 30 psi....are the cams at stock timing?
