2G 99 GST Fuse Box help
Grimis
1,096
12
Sep 5, 2003
Jersey Shore, Pennsylvania
ok, I need a pic or someone tell me if I'm missing something...
have a 99gst that im rebuilding for the wife, and notice that one of the fusible links AKA big A$$ fuse was busted/blown and the other missing. So i got them and noticed that on the 60amp that there is only 1 wire to the box facing the front of the engine. the 100amp has two wires, one on each side. is this how the 99's are wired or is something a miss?
picture would help.
From what I know 99's are wired quiet a bit different than 95-96 cars....
Tomorrow I'll run out to the garage and check on that for you unless someone gets back to you sooner...
Edit: I know on the passenger side of fuse box there should be 4-eight gauge wires. 2 on the front of a fuse on the FRONT corner of the fuse box. and 2 Feeding the rest of the fusebox from a fuse/relay from the side facing the fender....
In the given link youll see it says battery if you zoom in.....
I think the wires come from the alt go to the fusable link where the black dot is I think....I'll check tomorrow
Found a link here is a 99 Fuse box....Scroll down to see it
http://www.dsmtuners.com/forums/blo...e-box-relocation-cleanup-project-part-25.html
Dammit I lost the link that shows you give me some time to find it
http://www.dsmtuners.com/forums/hangout/298569-my-fuse-box-relocation-project-log-6.html
Find post 172
It'll say Fusebox Harness.doc and click on it
wow, thats a bit of info, but a simple picture would help me LOL. I dont plan on atempting what these brave soals have done, mad props to them.
a picture would tell me quicker, and the more i read into it, i think its fine but just need to double up, the prev's owner said every thing worked before the guy i got it off had his way with it...
ok thanks, I just wasnt seeing things LOL.
thats the problem owning 2 diffrent years LOL. Thanks guys for the quick help.
